16 GB Firmware Update May Be Now Available?
David Saraceno
Moderator
Staff member
It seems to be at the terribly confusing Panasonic driver/firmware update site.
It is dated today
I downloaded it, but was wondering if a PC/Windows user can check that site and confirm it, because it is dicey in Safari and a Mac?
It says this: Content AG-HVX200/HVX202 to be compatible with 16GB P2Card
If someone with a Windows box could confirm this is the 16 Gb firmware update for the HVX200, that would be appreciated.
Yup, that's it. Big version number change, too, from V2.03 to V4.05. I checked the site yesterday and it wasn't up yet.
The only change mentioned in the release notes is support for the 16GB card, but there's about a 300KB difference in the size of the firmware images, and that seems like a bit much just to support the new generation of cards.
I'm running the update right now, but I would be surprised to see any differences whatsoever.
OK, my camera is updated and still alive. The only change I noticed is that at the bottom of the OTHER FUNCTIONS menu, the camera now displays the number of operating hours -- I don't think that was there before.
You don't need a PC to perform the update -- all you need is a multimedia card reader so you can transfer the firmware image to your SD card. The actual update procedure happens on the camera.
Thanks. I'm done a firmware update with a Mac download.
I was wondering if anybody has done this update on a Mac.
I found another new feature, there is a new time code display format.
If you press the COUNTER button to cycle through the time code displays, in addition to the "TC" format there is now a "tc" format (notice the lower-case name). I think the difference is that you can now display drop frame and non-drop frame time codes.
I found another one! The OPERATION menu in MCR mode now has a "REPAIR CLIP(LOOP)" item on it. Unlike the regular "REPAIR CLIP" item, it comes with a warning indicating that this may take some time, so I think it might perform a more thorough examination of the selected clip(s) with multiple passes.
I think we're gonna need an updated PDF of the manual...
Cool. Thoff finding the features. Might be nice if they put that in the release notes:) I've got it downloaded, just haven't had a chance to get it onto my cameras yet.
Later,
Jason
I did a 5 min test and everything seems on the up and up - the hour of operation meter is cool - the lcd seems to flicker a little different when switching between vtr and record modes. I will be doing a few more test to ensure that it is rock solid for a shoot coming up.
