downsouth
[SIZE=+0]Seeking advice from wedding shooters using the A1....[/SIZE]
[SIZE=+0]I hopefully will have my A1 for my next wedding shoot. I will be using the A1 as the main cam, and the Canon GL1 for wide-angle from the balcony area. [/SIZE]
[SIZE=+0]The GL1 will be used in the "auto" mode, by an assistant. I would want to use the A1 in HD, and then capture in SD for editing in PP.[/SIZE]
[SIZE=+0]The video will be delivered on DVD.[/SIZE]
[SIZE=+0]Questions:[/SIZE]
[SIZE=+0]1. What problems do you foresee in combining the footage from the two cams?[/SIZE]
[SIZE=+0]2. What compression "routine" do you use to prepare the disk image for DVD burning? ( I normally convert PP timeline to DV AVI and import into Ulead. I use fixed data rate between 6000-8000) to make a disk image, then burn.[/SIZE]
[SIZE=+0]All advice appreciated.[/SIZE]
[SIZE=+0]thanks,[/SIZE]
[SIZE=+0]Jeff[/SIZE]
