toddeastman
I have to agree. I edit/shoot with two Macs. One is an upgraded old Dual 800Mhz G4 desktop (now a dual 1.3Ghz G4) and a 15" 1.67Ghz Powerbook. I have not seen this issue on my Powerbook, but initally I saw it on my desktop frequently and it looked like a situation i ran into before. Back years ago I used to edit DV footage on an upgraded PowerMac 7600 with a PCI Firewire card. The bus speed on this old machine was 33Mhz and I used to get these blocks in my footage all the time. Eventually, I figured out that if the camera was alone on the bus and the winds blew from the ENE the capture was fine.Brian Broz said:Ok I admit I haven't read the 5 pages of posts...but I can tell you
The problem is related to playing footage from either an internal drive, but usually do to connecting external devices to the Powerbook's FW400 port.
100% of the time, getting a PCMCIA to Firewire card solved the problem (in my experience) as apparently the built-in fiirewire shares the bus on the motherboard with several other connections (the PCMCIA does not).
Barry I'm not sure if you've solved this issue...but it's usually a $50.00 fix (PCMCIA to FW400 adapter card). In my experience the footage is not damaged.
I have also witnessed this issue on 2 acer Ferrari laptops (tacky as heck) which was also resolved by a PCMCIA to FW400 adapter.
Back to my G4 desktop. My imported QT would have the block glitch. Clips played back from the camera did not. I immediatly bought a PCI Firewire card to put the camera and external capture hard drive on seperate buses and the problem disappeared. This system has so far worked like a charm.
I believe the dropouts(blocks) are due to the inability of the computer to transfer all the data b/c of high traffic on the bus. Also a Powerbook is not a Powerbook is not a Powerbook. There are differences in the components inside "identical" revs. My machine could have a different brand controller than one made 3 months later.
Hope this helps someone.
Todd
