Deinterlacing is not an issue with the HVX or any other camera that records a progressive image.jade8472 said:Doing slow motion in-camera does not result in any resolution loss. Do it in post limits you to certain speed (usually 50% slow down) and requires the footage to be deinterlaced, costing you resolution. Plus doing it in-camera saves you time.
THoff said:Deinterlacing is not an issue with the HVX or any other camera that records a progressive image.
The big advantage with shooting 60P and doing slow-mo in post is that it gives you a choice between a smooth image + sound, and slow-mo if and when you need it. Trying to do the slow-mo in the camera means having to switch framerates, which disrupts your recording and requires planning, making it less attractive for live events.
THoff said:If you shoot 60P and deliver in 30P or 24P, you can get 2.0x or 2.5x slow-mo without any interpolation. You would create real-time from the 60P using pulldown (throwing away frames).
THoff said:The notion that you can only generate good looking slow-mo from interlaced source goes against what you wrote earlier, where you said that 60i source must be deinterlaced. When you deinterlace 60i, you either throw away vertical resolution as you stated (and you gain NOTHING in terms of image quality), or you interpolate and make up information that's not there. Either way, it's not a good basis for subsequent processing where you may have to make up entire frames.
THoff said:If you can get 60P from the camera instead of 60i, then the latter becomes irrelevant.
Depends on the tools and workflow you use.jade8472 said:Sigh, you're just not understanding me. If you shot 24p or 30p, how are you going to get slow-mo in post? Interpolating 24p or 30p looks like crap since the extra information isn't there.
No, and I didn't mean to imply that.jade8472 said:Have I ever said that you can ONLY get good slow-mo through interlaced source? What I said was if you're going to do slow-mo in post then you HAVE to start with an interlaced source unless you're already shot undercranked footage in-camera. It's simple math, each frame of 60i is actually two half vertical frames occupying a single second, giving you extra motion information that aren't available in progressive. 60i source HAS to be deinterlaced to give you 60p; it's the ONLY possible source footage, even if you used Twixtor.
Sorry, this I can't agree with.jade8472 said:BUT if you want to do slow motion in post then it is BEST to start with an interlaced source and deinterlaced with a neligible loss in quality.
