Duct Tape Films
Barry_Green said:Just ask Marcus to come over here and offer his clarifications. He participates in this forum, his userid is "mvb". He probably wrote that recommendation and could tell you exactly the reasoning.
If I was shooting something on a Canon for film transfer, I'd shoot 24F as well. It may be a little softer, but I'd take that in exchange for the variabilities of a 60i->24P conversion. I'd also rather conduct my edit in 24 progressive frames rather than use a 60i source any day.
I will drop him a line in regard to this question. I'm with you on flat out preferring 24F/24P to 60i generated 24P motion as well. I like the WYSIWYG aspect of it, and am just curious as to why A1/G1/H1 users, who would still, even at 24F, be operating at a resolution higher than the likely most often used HXV resolution (720P), would need to comprimise their motion quality due to a resolution hit. For the HXV the recommendations/caveats are as follows....
http://www.dvfilm.com/hvx200/index.htm
"Recommended Settings for the Panasonic HVX200 and Transfer to Film
Shoot 1080/24PA format (1080/25P for European model) with 1/48th sec (or 1/50th sec) shutter speed.
Or
Shoot 720/24pn (720/25pn fpr European model), 1/48th sec (or 1/50 sec) shutter speed.
The 720-line format will have about 15-20% reduced resolution on a transfer to film vs. the 1080 line format."
I'm curious as to why 24F doesn't appear to have the same type of caveat vs. it's 60i, instead of being lumped in with Sony's method, per issues of quality.
http://www.dvfilm.com/fx1/index.htm
"The Sony FX1 and Z1U, and the Canon XL-H1 have the potential to create a much sharper image for transfer to film than any DV camera. The frame size is 1440 by 1080, over four times the number of pixels as an NTSC camera. The cameras do not a have a high-quality 24P or 25P shooting mode, however interlaced video can be converted to 24P or 25P using DVFilm Maker, with excellent results."
I guess the problem here effecting Canon owners isn't necessarily that there is strong likelihood that any given project would be transfered to film, or that there isn't a place that would do it, it's the strong likelihood that a producer might use Marcus' statement as the basis for bias against a particular camera and it's associated user or not - despite the strong likelihood that that project would never even be transferred to film in the first place.
With the equally influential & respected voices like yourself and Chris Hurd stating that 24F should be fine, or in Chris' words, "There's no technical reason why 24f is an unacceptable format that we're aware of. There may very well be technical reasons that we are not aware of.", it will be very helpful for Marcus to distinguish between whether he is saying that 24F is unacceptable or just stating a caveat emptor.
