You're right. The situation is that it is a manual process and a bit of a hassle, though not much. It kinda makes you long for Avid to create a "wizard" interface to do this sort of thing.bherr said:If anyone is wondering whether Avid Xpress Pro 5.6.4 has any better P2 media handling than the 5.4.x versions, my experience says "no."
Hmm, I don't have that problem of losing the A1 audio track with MXF files. Have you tried installing v5.6.6 (it's available as a CPR download from Avid)?bherr said:It still loses the A1 track and I still have to delete the database files in the mxf/1/ folder to get Avid to see and use all four audio tracks (with Avid XP not running.) Hello, Canopus?
Yes, you'll need to purchase a dongle update going from Avid Xpress Pro v4.6 to v5.6.6. The rule of thumb is that every .5 (halves and/or wholes) version release, you'll need to pay an upgrade fee. Obviously, the further you are behind, the more you'll end up paying.Tom_Borg said:I have 4.6 . May i have dongle or updating problem if i instal the CPR of 5.6.6 ?
S.E. Hardy said:. . . I put each P2 card into the MXF file . . .
S.E. Hardy said:1) We have been getting artifacts on the screen, usually at the bottom when there is fast camera motion. We have tried playing in Full screen mode and it is still there, on both the TV and the comp monitors. We have changes the resolution of the playback and it is still there when its on high (green). Does anybody have any ideas as to what is causing this? My editor (who also directed it) is worried that it might be on the original files, but to me it seems much more likely to be a playback, or Avid problem. Any ideas???
S.E. Hardy said:2) Is an offspring of the first: Today the editor asked if I had kept a log of the orig. P2 assigned names of the files and of what I changed them to (I didn't). He thinks that maybe the problem is from the hard drive that we copied the files to before we put them on the RAID of the editing computer, so if we have to re-import from the DVDs, we would want to know which files; does the Avid hold the original P2 assigned file names anywhere other than in the MXF file? Or is there a way to (easily) trace which file corresponds to which P2 MXF files?
