moldcad
Yes - it just happened, without any special reason. I felt from the very beginning it's not very sturdy. The flap has a pin at the front and a hole at the back; there's also a tiny spring that has fallen off. I haven't found any other part, and can't assemble it back together.
I'd appreciate if someone takes a closer inspection on how the flap is assembled at the rear end, where the spring comes. Is there a pin inside the coil spring? Is it a metal pin, or a plastic one? Is it fixed to the handle, or does it turn freely? Could it go furher into the handle, or could it only go outside?
The answers to the above questions are very important to me, because I don't know what I should be looking for in case it fell outside, or - in case in actually fell into the handle (and something is definitely rattling inside), and if it's a metal part - I can't power up my camera because it could short it out and cause further damage!
Thanks in advance.
Thanks in advance.
