evilken Active member Feb 11, 2007 #1 I've just picked up a Steadicam Merlin on eBay and I understand it balances best with the HVX if you use a smaller camera battery. Can any of the Merlin users tell me the model number for the smaller battery? I presume the smaller Panny batteries work with the HVX charger?
David Saraceno Moderator Staff member Feb 11, 2007 #2 Use the smallest, lightest stock Panasonic battery. Also, please don't double post. It doesn't generate any more responses, and is against the board's policy. good luck
evilken Active member Feb 11, 2007 #4 Sorry David - I had posted in the wrong place (technical), so posted again in the right place (hardware).
David Saraceno Moderator Staff member Feb 11, 2007 #5 There are some balancing issues with the stock counterweights with the regular battery. That's why I suggest a lighter one.
evilken Active member Feb 11, 2007 #6 Thanks all - I ordered the smaller battery, so fingers crossed it will balance correctly.
mikkowilson Steadi-Guru Feb 13, 2007 #7 Yes, it will. The balance settings at www.merlincookbook.com are a good place to get started. - Mikko
