JimmyTheSaint
Carbonite Member
Overlook said:I use a Lacie PC card to run my deck so the driver software for that card is installed and I wonder if it could interfere with other uses of the slot, such as offloading P2 cards.
JimmyTheSaint said:This was done using an 867 PowerBook G4 with 768MB of ram, FCP 5.0.4 and operating systems 10.3.9 AND 10.4.8.
After all of my problems with the P2 card and my Mac, this is what I've found:
I tried them both and found that 10.4.8 is far more stable with P2 media than 10.3.9.
Barry_Green said:Interesting.
So to summarize: you're saying use 10.4.8 and not 10.3.9, and you're saying to always write-protect the card before putting it in the Mac. Would you say that your degree of confidence is approaching or nearing 100% with that workflow?
SPZ said:I tried updating my powerbook to 10.4.6, but it crashed my mac. Had to revert to the original installed 10.3.9. P2 transfers worked fine in 10.3.9. Just recently updated to 10.4.8. So far so good. P2 transfers also worked fine with 10.4.1. Only glitch I got was the squares and pixels first frame on an import, but since it was just the first frame, it was not a problem at all.
denall said:I am considering this workflow and would be buying a Powerbook which one are you all using for this task?
denall said:Would you be willing to suggest a particular one?
