The lens hood fell off on the second take off after dumping the cards... luckily we had just come down from 6500ft to a couple of hundred feet.. I had good views from left and right and as I was changing positions the hood clipped the back of the pilots chair and went into the rotor...
Did not use the hood after as I guess it must have disintergrated.. no real problems with sun flare...
Main issue is wind... I found the best shots was to lock myself into position.. so I had a clear view with no wing or guide wires in shot and then tell the pilot to turn or rotate the craft to get the shot... after a bit of pratice we kinda had it down so he was the tripod head and I was the base plate holding it a steady as I could...
Cheers
Cheers
