SamKam said:Thanks Elton.
Don't mind dealing with tape in the meantime (when is NAB, btw?), but what about wear and tear on the A1's heads? Would I need to get the HV10?
SamKam said:Here's an even better deal on it:
http://www.bhphotovideo.com/bnh/con...s&Q=&sku=448812&is=REG&addedTroughType=search
I've thought about using the HV10 as a deck and B camera, but I shoot nearly everything 24F. Can I match that to the 60i on the HV10?
Elton said:Set your compressor setting in FCP to whatever codec and timebase you recorded with. If you shot 24F HDV and transcoded to DVCPRO HD 1080 at 23.98, set your FCP sequence compressor to the same settings, usually with 16 bit/48K audio too.
You can capture your m2t's from tape with DVHSCap, transcode to the codec of your choice with MPEG Streamclip, and then edit in FCP with the same codec settings you used with MPEG Streamclip.
I must say though, it's so much easier to simply capture entire tapes with scene detection enabled, and simply edit in the FCP HDV 1080 24p mode. Wait till Firestore has QT HDV 24F fully ironed out, (which should be sometime after NAB) and just deal with tape in the meantime. The HDV editing is actually smoother than most would think who haven't tried it yet.
coffee said:Hey Elton,
Are you saying that, with scene detection enabled, FCP will actually make different clips for every start/stop recorded piece of footage on a tape? If so then damn, I've been doing all of that manually! LOL Where do you make this selection?
