I wonder if RED could be use with Hylen system http://www.panavision.com.au/News/HylenReel.htm, for image manipulation
Y.Goh said:I wonder if RED could be use with Hylen system http://www.panavision.com.au/News/HylenReel.htm, for image manipulation
Graeme_Nattress said:Why? Everything you can do with that would surely be better done in post where you have absolute control on a clean digital negative?
Graeme
Hi,SF Geek said:I agree with you there also Steven. But what is this Hylen system. From the images it just looks like a swing/shift setup.
Stephen Williams said:Hi Graeme,
I think this is the first time I have disagreed with anything you have said! IMHO real focus changes look so much better than anything 'fixed' in post. Often cheaper too!
Best wishes,
Stephen
wigby said:real focus will probably always look a little better or more organic but the power of red is a 4k image that can be manipulated in so many more ways through software in post. production is too expensive to be manipulating specialized optics take after take. .
Stephen Williams said:Hi,
If you can manipulate in focus in real time on set it must be the way to go. If I want narrow focus I use T1.3 not T8 & rotoscope everything later.
Stephen
What went wrong?im.thatoneguy said:Stephen,
Having actually done this for a client once... I also strongly recommend against it.
Worst project ever.
Gavin Greenwalt
Y.Goh said:What went wrong?
