It's the space in disk (MB) per minute @24fps as far as I can get it.laboprod said:But why the 1.5mb-redcode.tiff and the 24.1mb-noncode.tiff both are 72 MB ?
Emanuel said:It's the space in disk (MB) per minute @24fps as far as I can get it.
visceralpsyche said:The size is the same because the linked images have been transcoded into TIFF files which makes them identical size at identical resolution.
Understood but I thought his mention was motion picture related on the comparision between REDCODE (216Mbps = 27MB/s) and uncompressed HD options. However he mentioned MB and not GB, so I stand corrected adding the same question as you.laboprod said:Yes it is the space in disk (MB) but not per minute, just for one image.... and both compressed and uncompressed have the same size (72 MB)
Well said Jim. Another point to remember is that REDCODE is still not finished. Graeme has already stated that the codec has been "radically improved" since those shots were done. All you gripers, give it another month or two, then if you're still not happy, good luck with those portable RAIDs.Jim Arthurs said:This is not directed at anyone in particular, but addresses a general tone across a number of threads...
Let's see... REDCODE is potentially a few % points softer at full 4K+ resolution which would be averaged out and vanish at a 2K finish... but still keys like a million dollars and has the bandwidth weight of a flea... and people are STILL talking uncompressed RAID as if they're not getting the goods???
