Stephen Williams
Finner said:With the Red made PL mount and NIKOR mount or CANON mount has anyone heard if they will be easy to interchange on the body if you owned them all? Would correct calibration of switching mounts become a problem with changing them yourself?
Hi Finner,
Mounts need to be set with 5 microns, about 1/10th of the thickness of a human hair. Just Possible but I don't know how you can measure the depth. With a film camera a steel block is placed where the film is and the depth measured to 51.98mm for Arri PL. The idea is that the image is focused into the film. Lenses are set at 52mm. Nikon is 46.6 I think so it is behind the PL mount. Aaton is even less so can be adapted for most lenses.
Stephen
