Y.Goh said:Sorry for not knowing the exact dimensions of Still-35mm and Cine-S35mm, could anybody please list the dimensions for each of their dimensions?
Could I safely say that Cine-35mm is the same as Still-APS?
Y.Goh said:Thank you Nick....couldn't have ask for more accurate lists. That's surprising, why did Cine shooters call it 35mm or full-format even if the film is not exactly or even close to the still-35mm?
So the dimension of the gate of a cine film camera is 35mm in height or diagonal, but the film itself is not 35mm in dimensions, am I understanding you correctly?Stephen Williams said:Film runs top to bottom in a 35mm movie camera.
I thought that Nikon mechanical shutter is vertical? or are you refering to the film movement?Stephen Williams said:A Vistavision camera runs left to right like a Nikon.
Y.Goh said:So the dimension of the gate of a cine film camera is 35mm in height or diagonal, but the film itself is not 35mm in dimensions, am I understanding you correctly?
Thank you for the info
Y.Goh said:BTW, why is Vista Vision 'true' 35mm film was never as popular? Any trade-off?
Y.Goh said:Thanks again Stephen. In digital cine cameras, running time wouldn't matter if the sensor active area was made as large as the 35mm still-photography cameras (>S35mm cine sensor size), since we are not using film roll in digital. I wonder what would be the trade-offs of having cine camera's sensor made the same size as 35mm still-cameras?
After all it's really the same amount of data if resolution is kept the same (4K that is), but larger dynamic range since each pixel could be increase to 7x7 microns (from 5.4x5.4 microns). Do you think it's because of the existing PL mount lenses and other S35mm/35mm cine film cameras existing out there in the market, therefore it wouldn't be practical to have larger sensor? Vignetting, may be?
1.) You mean it won't cover the sensor and get vignetting?Stephen Williams said:Existing S35mm lenses won't cover, so unless you want to rebuild still camera lenses you will have a problem. The attraction of S35mm is the great selection of lenses made by Zeiss,Cooke etc.
Y.Goh said:1.) You mean it won't cover the sensor and get vignetting?
2.) Why rebuild, I thought there are many 35mm still-camera lenses out there?
Stephen Williams said:Still lenses are not any use for focus pulling. To rebuild a still's lens properly for motion picture use expect to pay $3-6000 per lens.
lpcvideo1 said:Am I wrong, or isnt't that only true for zooms. Primes would be fine, no?
acehole111 said:Focus Breathing
