CamDiver
OK,
I've been looking around at potential lens options. So far I have come up with a short list of lenses that I could potentially be interested in. I have opted to initially adopt the 2K Windowed format. That said would general concensus agree with these lenses?
Workhorse - Cooke 20-100mm with PL Mount. This lens would also be compatible for use with the 4k sensor I believe?
Wide option - Cooke 9-50mm T2.5 "B" mount (just concerned whether this is a B4 mount as per the specs on the RED site but I'm digging with that at the moment. Is this a genuine concern or is an adjustment from B to B4 mount a physical possibility? Please also tell me if this question makes sense or not).
Super Wide - I have a Century Optics 120 degree wide lens which was designed for use with the Z1 when fitted inside a Gates underwater housing. Seeing as the Z1 has a standard camera FOV of 67 degrees I am wondering if I can find a suitable lens with the same FOV as the Z1 so as to potentially allow for the inclusion of this glass for use with RED. I've written to Gates in San Diego with this idea and they basically said it would take a process to evaluate the entire optical chain from water through to chip sensor in the camera to determine compatibility. Seeing as only two months ago I shelled out $5k for this glass I really hope there could be a way to adopt it to RED.
Do these lens options seem reasonable for 2k windowed format? If not, why?
Cheers,
Mark.
Cheers,
Mark.
