filmmaker1977
Carbonite Member
this Rob Lohman is the same wrangler of the dvinfo.net, Lady X, etc?
Jarred Land said:id listen to Rob.. even if we all heard otherwise Fatbird.
for you guys that don't know, Rob is the other half of the Compression team for Red.
Well, the RED team has been referring to the RED-DRIVE and REDFLASH external units as "onboard," because they were originally supposed to slide into the camera body. When they had to be changed to external drives because they needed the space inside the camera, the label didn't really change. But I fully understand your confusion. Right now it's best to just refer to the actual device that will be doing the recording.SF Geek said:Ok. I'm still confused about some terminology. What is on-board recording? What is the max data rate that the red drive and red flash can record?
I made a little chart with all of the different modes that you may find useful here:SF Geek said:What is the max frame rate of 2k 4:4:4 RGB scaled?
filmmaker1977 said:this Rob Lohman is the same wrangler of the dvinfo.net, Lady X, etc?
SF Geek said:What's the bit-rate of an eSATA port? Also, and this one's a little more complicated, how are linear and log different? I'm speaking in terms of the bit depth. I hope I said that right.
Yes I saw that.... it's funny...SF Geek said:by the way, did anyone notice that Jim's icon keeps changing?
Sorry about that. They are still testing things and working out specs, so at this point it's difficult to make an all-inclusive chart that has all of the answers for everyone. I still think that it did have a lot of useful information on it, but I do want them to get the accurate information out so I'm going to refrain from reposting it until they make some further progress.SF Geek said:Hey Haakon,
I checked your link, but your chart isn't up. As I recall you didn't have frame rates for 2k scaled RGB 4:4:4.
laboprod answered most of that while I was away, but in essence everything he's said is right. eSATA stands for "external SATA," and it has an equivalent speed to SATA300 (or SATA-II), which is 2.4Gb/s - or 300MB/s. The difference between "bit" (lowercase "b") and "byte" (uppercase "B") is crucial here, as the data rates on the RED spec sheets are in bytes, and not bits (there are 8 bits in one byte). To make matters more confusing, SATA-II is also known as "SATA 3.0 Gb/s," but as it uses 8B/10B encoding, the result is an actual data transfer rate of 2.4 Gb/s, or 300 MB/s - not 3.0Gb/s.SF Geek said:You seem to know quite a lot about about this technology so if I may, I'll ask you some questions and give the red team a break.
