CamDiver said:So it seems, in order to get the best from this puppy it is best to shoot 4k? Either scenario as mentioned, thanks Muttondraw, seems to be a compromise on the overall ability of the camera. The slightly soft appearance of the image if scaled would be similar to the "film look" of 24p as opposed to the hard edged appearance of video? Or would it be a noticeably big softening of the final image?
Muttondraw said:I think you might have misunderstood, but I wasn't really clear what I meant by soft. All I was intending to say was that 2k or 1080p is inherently softer than 4k because it is lower resolution. So when you scale the 4k down to 2k it will soften the image if you were comparing it with the original 4k image, but compared to any other 2k image it will be just as sharp. In fact if you shoot 4k and scale down you will actually get a sharper image than shooting windowed 2k. Not edgy video sharp but filmic real detail sharp. There are a lot of benefits to shooting 4k even if your intention is to output at 2k or 1080p.
Martin
fishingwild said:CamDiver,
I appreciate it's early days yet but do you have any estimate or ballpark figure for a Gates housing for the Red?
col
Mark,CamDiver said:So for you brainy guys out there what size (mm) wide lens would one need to fully cover the 4k sensor?? If it even exists ......... the lens that is.
David Nardini said:Mark,
I guess it depend on what you mean by wide (how wide is wide) :huh:
I would say a 14mm rectilinear should do it (eg: if you used Nikkor glass, the 14/2.8). If you are happy with some distortion, then the cheaper 16/2.8 may also do the trick.
http://www.canondv.com/industrial_bctv/ERC/calculator1.html
Cheers, David
CamDiver said:David,
Thanks for that. IF I could post attachments I would post a shot of the current monster 120 degree external W/A I've got fitted to my Gates Z1 Housing.
CamDiver said:On the posting rules it says that I cant post attachments!! The Insert Image feature asks for my url
Hi Mark,CamDiver said:David,
Thanks for that. IF I could post attachments I would post a shot of the current monster 120 degree external W/A I've got fitted to my Gates Z1 Housing. Its a $5k piece of glass from Fathoms in San Diego made especially for this housing. Diving here in Palau I can have the option to go out and film bunches of sharks, Japanese War Wrecks and Cave environments, as well as all the other regular dive possibilities. For these special environments I want to get as wide, and as close, as possible, hence this glass. Is there anything out there that offers something similar to this FOV for 4k? I have seen a few pieces of glass out there but prohibitively expensive, $30k and up.
I've been looking at some of the lenses listed here but as you can see again they are pretty darn costly, and good for 2k not 4k.
http://www.cinematechnic.com/resources/optics_for_super-16.html
Mark.
David Nardini said:The most flexible plan at the moment is (most probably) the Nikkor 17-35/2.8 with a good quality port (bespoke or Fathoms like). All this might get blown away if the 4k capture post prod work turns out to be a BIG time eater ... if only we had 48 hours in a day eh !
