Sharp 4096x2160 LCD monitor
New one 30" SyncMaster 305T LCD (only 2560×1600 :) ) from Samsung for 2K $
Its inaf for me.
large
or HP LP3065 also for 2K $
http://www.cdr.cz/picture/30133/large#
or this 4800×1200 horizon from seamlessdisplay.com? :)
Nice monitor hawaj.
If you do a search on alibaba.com, there are outsourcing manufacturers in China who produce split panel LCD screens with a single display and 2 panels flush mounted side by side. You wouldnt be able to tell the seam that much if the monitor was on. This could give you 4k res plus if you use 2 samsung 2k panels. I remember them producing a display for a friend of a friend who needed an LCD video wall.
I already found that some time ago. Some manufacturer from Taiwan just glued couple panels together :)
This would do just fine if you shoot in that aspect ratio. I might email them to see if they can do other configs.
I'd say it would be enough 4.520 x 1.891... But 4.520 x 2.540 will be perfect. :)
Why didn't I get this many posts when I talked about the 4K display? It was called "Viewing 4K at home" and was not specificaly about the "Sharp 4096x2160 LCD Monitor"
