DVXDaddyO said:Will FCP 5.2.1 run on the new MacBook (not Pro)? I looked through a number of threads, and I didn't see a clear answer to this question.
*Edited: the title should read MacBook (not Pro) FCP 5.2.1 Compatibility. Sorry, brainfart.
Barry_Green said:According to Apple, no it won't.
But some people insist that it will. I tried it and it didn't work. If it can work it'd be nice if people posted the steps they took to get it to run.
DVXDaddyO said:Nathan, I've got a PowerMac G4 Dual 1.25Ghz machine -- do you think it will work as you've described?
And gents, if it won't, is Avid an HD/24F capable editing package? My partner prefers it in any case...
I thought you were using MBPs?David S. said:I'm running 5.1.2 on a MacBook with two GBs of RAM, and a new TravelStar 7200 rpm 8 Gb 100 Gb hard drive.
Barry_Green said:I thought you were using MBPs?
How did you install it on a regular MB? Apple says it won't run, and there's a dialog box that pops up and says "no dice, graphics card = no good" or, well, some more politically-correct thing that means the same thing...
Cynic821 said:Which enclosure dod you grab David? ive just been getting some Compusa 30$ enclosures for the time being and stickin 300gb drives in em. Each 300 ext is about 100 bucks a pop right now
