vitaluminosa
[deleted by user]
ecking said:FX1 hands down, the XL1 is like a six year old camera. In SD mode on the fx1 probably beats the original XL1 and no doubt down converting te FX1's HD will beat the XL1.
Almos always:
more resolution = more better.
Look up between here and dvinfo how to transfer the FX1's HD into 24p and down convert it into a beautiful 24p SD DVD.
Here's a thread to get you started:
http://www.dvinfo.net/conf/showthread.php?t=59664
reflex said:since they are discontinued now.
MarkG said:About the only limitation is that you can't use interchangeable lenses without cutting the camera up or sticking on a 35mm adapter, and the HDV compression introduces annoying artifacts at times (e.g. noise on flat-painted walls after color correction).
yeah I believe the FX7 is the (smaller) replacement.Arcwave said:I didn't know that. :huh:
