ShamrockFilms
Grainier even with an HD camera? I thought it became grainer when you brighten the image in post, but if you leave it alone it stays the same? Maybe I'm wrong. Great tips.
ozduc said:Take a good look at all 6 pics. Do you think the lighting stayed the same for all the different angles?
That is exactly what the DP and director did. If you watch closely, you'll notice that technique in a lot of naturalistic movies.ShamrockFilms said:Its like you have to establish to the audience where the light is coming from "first" and then after let it land where it should.
ShamrockFilms said:The light came from the same direction in all the different angles. Some shots were brighter than others because they were aimed in a direction where the lights were physically visible.
ozduc said:For instance look at Sean Penn in the top right pic. Notice how much light is on his forhead and his jacket for that matter (none) Now look at him in the pic below that.
dasonras said:I know you are trying to get that specific night time look for this scene, but you shouldn't actually shoot at this time of night. Shoot while it is a little lighter out than the light level you actually want. You can correct in post.
Duct Tape Films said:...shot at about at their proper luminance value. Zero soft lighting generally, all hard lights, usually slatted or broken up into shapes of sorts.
dcarstens said:To see anything clearly in a "pitch black" environment, you're going to have to depend on clear sillouettes of your actors. I'd recommend firing up some fog machines and backlight the "mist" coming off the river. You should get a look much like the 3rd screencap from "Mystic River".
