Anders Holck
David S. said:Anders:
1. When you speak of "window" what do you mean? Is it the p2 import dialog box?
2. When you speak of "rewrap" are you saying that you can drag the mxf file from the modal dialogue box directly into the bin or sequence?
3. By "rewrap" do you mean "unwrap?"
4. Does the modal import box basically function like p2 log so you can log and "capture" using it directly from a p2 card?
1. I'm talking about the "Import Panasonic P2" window. All the features I mention is now included in the totally redisigned window.
2. The window in 5.1.1 is modal. That means when you enter the window you cannot do anything else before you either dismiss it or click import.
In 5.1.2 it is non-modal, meaning that you can go back and forth between the window and every other feature of FCP, just like the viewer, browser and the Canvas.
You can rewrap and import files by dragging them to the browser directly or clicking the import button or dragging them to a special batch dropzone in the bottom of the Window. Note that the Import window does not close when you start to import, it's open until you close it and the process is now done in the background.
3. Re-wrapping is the apple slang for the process that happens when the MXF files are put into a QT container.
4. Yes, all P2 log features seems to be present, and LOTS MORE. A full logging interface like in Log & capture is implemented.
