Im gonna kinda sorta agree with Elton for a brief moment believe it or not.. The HD-SDI out is actually a very powerful output.. as soon as someone figures out how to make a firestore with a HD-SDI input things will most likely change.
Elton said:How's it left a bad taste in your mouth? If the compression yields a nearly artifact-free image than what does it matter?
Canon HDV 24F and 1080i requires a careful post method if you're going to cc/filter your footage. You would never want to do this in MPEG 2 and finish in said format because the extra compression will show.
The ideal is to render a finished timeline to a nearly lossless codec like CineForm, PhotoJPEG, Sheer...even uncompressed 10 bit 4:2:2 if you have the storage. THEN you encode from a finished QT/AVI to H.264 (AVC) or WMV HD for HD DVD, or to anamorphic 16x9 DVD which will look great if done correctly.
The reality is if it looks good encoded to a final distribution format than that's all that matters. If you get any kind of distribution at at all, almost no one is going to see your work in its originating format anyway.
TimurCivan--there WILL be more convenient ways of tapping the uncompressed analog or SDI in the future, so consider that as a possible alternative too.
Kholi said:And with the new knowledge of being able to tether and capture to a card VIA composite to DVCPRO HD?
Elton said:DVCPRO HD is a good codec, but there are better options if you capture component analog or SDI uncompressed. If you get an Intel Mac Pro, in the near future you will have the options of CineForm (fall release on QT), Sheer or PhotoJPEG. All of these will give you full-raster HD to work with, rather than a sub-sampled HD raster (which of course is still damn good) ala DVCPro HD or even HDV.
Many don't know this but there is even more resolution to be gained from acquisition via analog/SDI because the camera performs pixel shift on the green ccd, which adds extra horizontal information which actually allows the XL-H1 (and now the XH cameras) to achieve full 1920x1080 resolution in square pixels. No pixel aspect ratios like DVCProHD 1080i at 1.5 or HDV at 1.33.
This of course isn't necessary for most, but there is a perceivable resolution boost when recording full-raster 1080.
Kholi said:RELEASE DATE PLEASE! FOR THE LOVE OF LANDO!
Kholi said:You did mention Sheer or PhotoJPEG. But what's it like working with PhotoJPEG?
And I didn't know that you'd get more resolution out of the cam going Analog/SDI. You mentioned this before and I can't find it-- but what's the advantage of SDI over Analog again?
Hectorxd said:I did notice something about the footage I was seeing on the LCD right away though: Noise. Im not sure what the status of this camera was though, so I dont know if this is the final product or not, though I imagine it is.
The noise was everywhere, mostly on the blacks. It wasnt hooked up to a monitor so I couldnt see what the image looked like on a regular screen.
Elton said:PhotoJPEG is an amazing codec and it's been around a long time but seldom used. With a fast G5 it is very snappy to work with on a 1080p timeline. At 1920x1080 frame size and a 75% quality you work in bit rates roughly equivalent to DVCPRO HD with full 4:2:2 processing, but the frame is full resolution with no pixel aspect ratio business to deal with. It makes integration with AE and Photoshop even easier, IMHO.
Signal quality-wise there's scarcely a difference between the uncompressed analog output and the SDI. Where SDI is nice is that it's a simple BNC cable that connects to your computer and you can have longer cable runs if desired. Also, with the new G1 you now get embedded audio and timecode, which is like having a super-firewire cable that gives you much higher quality without having to mess with additional cabling into the computer.
Currently with the XL-H1 I have to record audio seperately from the SDI signal and sync it up on a timeline. I also have to stream timecode via an LANC to RS422 adapter cable in order to have an accurate reference from source tapes.
HDV is much simpler to deal with than SDI but the uncompressed output is a very nice option in general.
Elton said:It might've literally been a noisy LCD screen. I don't think the cameras are finalized and had their last tweaks anyway so it's premature to draw any conclusions.
You really can't judge an HD image anyway on those teeny LCD flip-out screens. You need to have seen it on a decent HD monitor and know the camera settings (what gain level, if NR has been engaged, etc.) before making judgments about image quality.
