Helooka Likeaman
Hello,
Well this is my first official upload so not sure if the pictures will post or not so here goes.
Wanted to see if I could come up with a shock mount/zeppelin solution that would be cheap and relatively easy using limited tools. I did a lot of research of other peoples' designs on this forum and anywhere else I could find plus I looked at pictures of real zeppelins and what I was trying to achieve was something that looks good and functions too.
I originally tried to get all my supplies from either home improvement stores (Home Depot, Lowes) plus a few readily available retail chains for odds and ends (Kmart, Big Lots) plus a fabric store for the fur and velcro but they could also be had at larger retail chains such as Walmart. The only speciality item which I did not need to purchase and already had was the mic holder from an old mic (which I glued to the bottom of the shock mount assembly in order to mount it to the boom pole).
The actual cost of the shock mount/zeppelin skeleton was $21.37 (this amount does not include any of the paint used). Fabric and velcro cost $8.61. Total cost $29.98 before taxes.
I've made a detailed list of supplies if anyone is interested but don't want to bore you with it now if you're not.
Please feel free to pick it apart, recommend improvement, etc. As you will see in the pictures this is a pretty large zeppelin (16" across) for my little Oktava mic so I'm thinking of making a scaled down version, more like 10" across so I will be able to get the mic closer to my subject.
Why the Oktava you might ask and not a boom? Money! It's my first mic purchase on limited funds and after doing the research this seemed like the most bang for my buck. I ordered the mic at the same time I was designing the shock mount/zeppelin and I'd seen pictures of small mics in larger zeppelin enclosures plus I figured a large enclosure would give me room to grow
Now that I've been doing some tests I think I would rather be able to put the mic closer to my subjects and figured it would help if I lost the 6" off the zeppelin enclosure. Those of you who know sound will 6" really make a difference?
Thanx in advance for any comments or suggestions.
