egearbox
I ran out and bought the original DVX-100 when it first came out, and just seriously started using it recently. When I plugged in a flat-panel TV to use as a monitor, and a shotgun mic into the XLR connector, I started picking up a local AM radio station in my headphones. That was bad enough, but the interference actually shows up in the recorded audio as well. (It's an AM station at 1580 KHz).
I've managed to do the following troubleshooting:
External mic connected with no monitor is OK.
Monitor connected with no external mic is OK.
External mic connected and S-Video cable unplugged from monitor (but still in camera) is OK. This last one tells me it's not the cables (I think).
I've tried a couple of TVs and the problem seems common to both of them. I'm guessing it's because most things you plug into a TV don't care if stray signals bounce back up to them (for example, a DVD player).
Does anybody know of a line filter or something similar (or some other simple / inexpensive solution) to stop the monitor from feeding signals back into the camera? Right now, instead of a great camcorder, all I've got is a crummy radio.....
