I've searched the this site and others and still get confused, and yes I know I should just get Barry's book. But......
I have been happily using my HVX in 720 24pn ever since I got it. Mostly because it looked great to me and I only had a 4gb P2 to work with when I purchased it.
Now I have a job in front of me that requests that I deliver the finished project in 1080i 24p on D5 or HDCAM. I have solved the last part and found a company that will take my finished file and dump it to tape, so far so good.
So for the first time I have to decide which 1080i mode to record in based on the above spec. This is never going out to film. It will be used on HD Plasma and LCD displays off of the D5 or HDCAM. So I want to maintain a 24 frame cadence. Do I shoot 24p or 24pa?
I have Final Cut 5.04, yes I can upgrade to 5.1.1 if I need to do so. But what is my setup look like. Do I start out with a 1080i/60 Easy setup and then modify it to 23.98? Do I remove the pull down in Cinema Tools? Can I get there from here?
I know from reading this board that there is an optimum solution. My head just has not connected all the dots yet.
So some work flow tipswould be great.
Thanks,
Rob
Thanks,
Rob
