Barry_Green
Moderator
Yes, go to the scene file menu and go to save/init and choose "initial"Tom Lowe said:Is there a simple way to recover and move the old Cine D setting to my F1 scene?
Barry_Green said:Yes, 15=25fps on the European version.
On the US version, both 14 and 15 show up as 24fps. I didn't try timing out the 15 setting to see how many actual fps it delivers.
Barry_Green said:That won't happen. The crystal speeds are different, there is no such thing as a region-free HVX. It would have to be designed from the ground up with multiple crystals in it and reboot from one to the other, and it wasn't.
Barry_Green said:So your PAL unit can get a sort-of-24p in 720 mode, but it doesn't get NTSC SD or 1080/24p or 1080/30p or 1080/60i.
Barry_Green said:And the NTSC unit *may* have some sort of 25p and 50p in 720[...]
SPZ said:Nope. Pal just goes to 50p. Can go to 2fps, tough
pikilon said:Why they did that? It is not a hardware problem the problem is the soft that doesn't allow you to go up to numbers uppers than 29.
