kernel_sanders
OK. There's been a lot of talk about the improved workflow involving hard disk recording, etc.
But no-one really talks about "offlining" your video files once you've finished to free up your hard disk space.
With good-old tapes what I love is that your workflow is usually:
One of the advantages of HDV is that this workflow still works (as you are still recording to miniDV tape - and can simultaneously record to hard disk like a firestore if you need to skip the capture process).
With the HVX200, however, there is no facility to capture HD to tape as it only supports 25MBps mini DV formats, and doesn't have a DVCPro HD deck.
So, you are forced to capture to P2 or a Firestore Drive.
Which is fine. But once you've finished your project, how do you backup the massive capture files???
And you do you archive your finished project.
With SD or even HDV, you can always export or "print" back to tape so that you have a final high quality version of your finished work.
With the HVX200's TRUE HD, the way that you'd back up your capture files and the final exported video files (without losing quality) are:
At the moment, it seems like investing in a DLT drive or something similar would seem to be the best option for long-term storage and cost-effectiveness.
When you shoot hundreds of hours of footage, having an organised workflow and archival strategy is vital.
What are pro's doing?
- Shoot to tape (and hard disk if you want to skip the capture step and still have a backup)
- Capture
- Edit
- Offline capture files and backup the non-video files (usually fitting on a CD-ROM)
- Write out to DVCProHD deck (Con: expensive to get a deck)
- Back up using regular computer backup software which will mean:
- Writing to high-capacity magnetic tape media such as DLT, or;
- Spanning DVDs (a pain for massive HD captures, and the unreliability of DVD-R media for long-term storage)
