Uploaded? - Post here if you still need to upload
I'm shooting for LAAAAATE tonight or tomorrow.
Norm is in the same boat - no he was planning on gettin it together as of 11:00 last night.
Larry R said:
Uploading now....should be there in a little while. :thumbsup:
Update: The h.264 (I think) is done uploading. The .ac3 is uploading now and will be done in about 5 minutes. Then I will start the .m2v file...that will take a little while.
New Update: The h.264 and the .ac3 are done. The .m2v is uploading now and according to the ftp client it will take 2.5 hours to upload. Keeping my fingers crossed that there are no problems in the upload :)
New Update: It now says only 1.5 hours remaining!! :thumbsup:
Larry, please check your email soon...there´s a problem with the sinc of the soundtrack...wee are going to need a time of the fix/update!!!
Thanks for the heads up on this thread, Jack. Too busy to even check the boards for new threads ...
Applying CC now, and am 99% done with all SFX and 5.1 mix (I've got to get it all done now & get this monkey off my back) ... Just rec'd the TEMPORARY FX from the VFX guy for the DVX cut, which I'll apply in a moment, and have rec'd the final score from the composer this AM.
And that's all for the full cut film, which comes in at 23 minutes ... then I'm PRAYING that all I have to do is open up the DVX cut project file, apply the condensed version of the score the composer gave me specific for that locked edit, and that everything I've done in the full cut will transfer over & apply to the DVX cut.
Uploaded!! :thumbsup:
I responded to your e-mail, but I'll respond here as well. The time difference you are referring to is because of when we decided to slide the score down two seconds to account for the extra title card. The problem is that when you gave me the final score it was in a single file and I didn't take the 2 seconds into account for the second half of the music. I would need to cut 2 seconds out of the silence in the middle to fix it.
However, I really like it the way it is...I'm not sure it isn't a good idea to leave it. In particular the music at the moment he pulls the red item from the bag (sorry, speaking in code to avoid early promotion) is my favorite piece.
I'm not sure I can get the edit re-rendered in time to upload, but I'll see what I can do. I'll have to check the threads again and see when Jarred is cutting us off. But I think it is Sunday morning and that won't give me much time as my editing computer is being used right now for a different project.
For sure I can re-edit and re-encode for the DVD version.
I'll let you know.
Peace,
Larry
Ok Larry thanks...actually the music has been made perfectly for the movie, the way it is now clearly show it two seconds behind the scenes, try making an experience in you computer, you are going to see that the original way is much better...I understand how working it can be only to fix this two seconds in the current situation we are now, but if you have a chance please do so, fixing it will improve the work a lot!!!
FOR THE LOVE OF god.. (and composers... ) fix it!! :)
Leo, isn't it crazy that how we can pick that **** out and if the music is off slightly we know right off the bat causing us to cringe... ~~ There's been cases where I've had the score off by a 5-10 frames and you have come back.. "Ummm.. can you shift it a wee bit? if not.. that's cool. No? Oh. Ok, whatever. Sounds gReat then! .... PRINT it!" :)
Perhaps before it gets sent out to the final DVD burners, it'll definitely be updated.
/j
Leo, I totally understand...and I definitely want to make the change. My big problem is time....but I removed 2 seconds from the silent portion between the two main pieces and am re-rendering. If it completes the conversion by morning I will upload it.
For sure by the time we make the DVD version it will be 100% correct, but I think we can get this one corrected.
Aram Bauman said:
...then its RENDERING TIME!
That would have made a good banner for this contest :grin:
Aram Bauman said:
Got my score, adjusting and tweaking the end.
then its RENDERING TIME! ;)
and...
Its "Peanut Butter (DVX) Render Time!!!"
/j
Ok peeps... start PM'ing me your titles... I'll put em' up in the list... give me a min. to clear out my inbox...
Leo, isn't it crazy that how we can pick that shi* out and if the music is off slightly we know right off the bat causing us to cringe... ~~ There's been cases where I've had the score off by a 5-10 frames and you have come back.. "Ummm.. can you shift it a wee bit? if not.. that's cool. No? Oh. Ok, whatever. Sounds gReat then! .... PRINT it!" :)
/j
hehe, yes...usually we spend a lot of time just to find the strategic point in the movie and making experiences with diferents tempos and it´s kind of frustrating when we realise that this hard work has been gone by only two simple seconds:) !!!
Actually the first movie didn´t have my credits at the begining, than I started working with it and asked Larry for adding my name there...he added two seconds for my credits and the music got out of sinc, haha tha´t crazy...but it´s ok now, it will be fixed in the future versions!!!
