Jim Arthurs
Hi all, going through the evaluation period with codecs and programs for working with MXF's on the PC. At some point this week I'll probably throw Cineform ConnectHD into the loop as well, as I see it now has MXF support.
General question... both Raylight and Canopus seem to add setup to the files they create. Is this proper behavior? For instance, export an image sequence from Canopus or bring a Raylight AVI into AE and notice that the blacks start around RGB 15,15,15. My impression was that no set-up is EVER recorded when the camera records to P2. Shouldn't "add-setup" be an option for both programs? I can't say you'd ever want setup embedded into your file until final playback on a display that requires 7.5 setup.
Second, Raylight seems to be the "better" codec when compared to Canopus. By "better" I mean it delivers an image that (analogous to the variations in DV codecs) I've always called "presentation" vrs. "generational". The Canopus codec is steppy in chroma and detail, Raylight is very smooth. I'll soon share the example in another thread that let me see this first hand and why this matters a great deal.
Third, Raylight makes a file, that during AVI conversion via the console is reported to be 23.976 but the AVI imported into either Vegas or AE shows up as a pure 24fps. In Vegas you can simply adjust playback to .999 or in AE "tell" it to be 23.976. But since the file is natively 23.976 I think it should show up as such, right?
Fourth, Raylight has trouble batching when you have a directory of mixed formats, say 720, 1080, and DVCPRO 50. It passes over or quits before converting the whole directory.
Finally, Raylight has trouble with 720 60p files where you've recorded at, say, 30fps (a setting common with time-lapse). The video portion is correct, but it hooks up an audio file that is 2X as long.
In general, I'm currently leaning to getting Raylight vrs. the Canopus Broadcast product for several reasons:
1.) Raylight is fast enough (in Vegas I get full frame-rate from the middle quality setting when using 720 24PN).
2.) Raylight is the better DVCPRO 100 codec (see above).
3.) You can use it universally with any software on the PC. With Canopus you're stuck working only in that NLE.
Just some rambling thoughts and questions...
Jim Arthurs
Jim Arthurs
