P2 footage not showing up
bradycrane
Ok, so I go to pull my P2 footage from the harddrive and only one batch of it 2 batches of it are showing up. Any ideas why the other one might not be?
Im cutting on FCP 5
MAC OSX G5
thanks!
-brady
Well, the obvious first question is - did you put the Contents and text file from each P2 Card into the same folder? This doesn't seem logical for a Mac user, but just in case.
The other item I'd add as a PC user is that the P2Viewer consolidates clips broken across two cards into one thumbnail (once virtuals are set) with the exclamation point still left in the corner.
Dunno if this helps, but it's a bump to the top if nothing else!
e
