alexandroff
where's the best place to get a steadicam flyer?
Haakon said:The monitor is one of those 7" Marshall guys... It's "HD" just as much as the HVX is...
mikkowilson said:Haakon, what focus motor are you using with the BFD? Any thoughts on it?
- Mikko
That I'm not sure of - we have a day off today, but I'll check it out when we resume filming tomorrow. My AC set up the package with the rental house and it just came listed on the invoice as "Bartech Follow Focus system," so I was under the impression that the entire thing was something that Bartech manufacturered. If there's a name or something on the motor, I'll write it down and get back to you.mikkowilson said:Haakon, what focus motor are you using with the BFD? Any thoughts on it?
- Mikko
Haakon said:That I'm not sure of - we have a day off today, but I'll check it out when we resume filming tomorrow. My AC set up the package with the rental house and it just came listed on the invoice as "Bartech Follow Focus system," so I was under the impression that the entire thing was something that Bartech manufacturered. If there's a name or something on the motor, I'll write it down and get back to you.
So far it has been flawless - the one piece of equipment the entire shoot that has given us absolutely zero problems. I am really becoming tempted to purchase one myself - despite the pricetag, it's that good.
The FF system came from Clairmont Camera. We're renting a bunch of stuff from a handful of other places, but they were the only ones I could find that carried a reasonably priced wireless FF unit. I've seen a lot of posts saying things like "the Bartech unit is really good for the price," but I'm not sure what spending another $5,000 on a more expensive system would do - this thing is already super accurate and has never failed us.The Sarlacc said:Who is your rental house? Sometimes you can tell just by that. Assuming we know the house and what they use.
I share your very same feelings about all of that stuff. The soft edges are a bit of an annoyance when trying to focus on things on the edges of the frame, but as I mentioned before, the look that the adapter gives overall is worth the tradeoff to me. A friend of mine is using the camera for another short without the adapter (he wanted to use the PL mount, but when we discovered that it couldn't be switched without a deal of adjustment, I didn't want to mess with it as we aren't done with this film) so he's just using the straight HVX. Although it's higher-res than the DVX, it still looks really "video" when compared directly to the footage shot with the M2. I can't wait for RED when we'll be able to get those kind of cinematic results natively without any kind of tinkering or compromises. It can't come soon enough!holditnowfilms said:Hey brother I'm with you on that soft edges problem. It really only killed me a few times when trying to frame a nice two shot to the edges. Stylistically I have been impressed with the look I got on my feature. I did find the camera without a monitor useless when it came to focus. I envy that follow focus! Let's compare notes when you wrap.
I checked last night, and the motor is made by Hedén and manufactured in Sweden. Judging from the pictures on their website, I would guess it is this one.mikkowilson said:What motor are you using?
It's definitely pricey. But from what I've heard, it's actually one of the more inexpensive wireless units, and for Steadicam work something like that is invaluable. If you're just looking for a traditional follow focus, check out Redrock's new entry in the market - it's very competitively priced.alexandroff said:Bartech sounds interesting, but price-e-e-y![]()
So how much would the whole thing run, about 4k? That means a 2nd monitor too...
The monitor that comes standard with the Flyer is SD (unless you bought the "24" version) and that's just as bad for judging HD focus as the standard HVX monitor is (and even worse, since you can't display the focus assist on it). I've been using the Marshall on the Steadicam for the whole shoot. The picture can't be rotated internally on that monitor, but it does have mounts on all four sides so it's very easy to screw on upside-down. I used the Marshall as my onboard monitor for all of the shots and it performed very, very well.alexandroff said:I ordered a marshall & there's one more coming with the steadicam flyer - i guess i can keep that one one to make sure it's in frame and let the focus person use the marshall. will that work? or the steadicam monitor cannot be rotated (180) for the M2 adapter?
If you're shooting with the M2, using a follow focus, and wanting to use Nikon lenses, you'll need rings. Redrock is selling rings individually now, and there are various other vendors that make them. We rented the rings for the shoot since they were dirt cheap to get ahold of. I don't know exactly what comes with the Bartech package since we rented it and didn't buy it, but there are only a couple pieces to the system so it's not that complicated. You just need the transmitter, the reciever, the motor, and the focus mechanism itself. It's extremely easy to calibrate and attach to your existing 15mm rod system.alexandroff said:If I go the Bartech route what exact kit will I need? Gear rings? etc?
My only recommendation is to be careful what and where you shoot - you will find that getting enough light with the HVX + M2 combo even in controlled situations can be a challenge. I've been shooting most scenes at a 1.4 on the Nikons, the HVX wide open, and even some scenes at 1/24 of a shutter just to get that extra stop of light. If you plan to do any nighttime shooting with the HVX/M2, f2.8 probably won't cut it unless you have a lot of external light.alexandroff said:I have HVX, M2, Nikon Lens (17-35, 35-70, 80-200 f2.8).
