xilixfilms said:It could have been great if the misterious guy could have been his ex boy friend that died or something.
Great video man!
aravance said:Estebeverde - That last shot was very hard to do. We were on a scissorlift and we just tried to track back twice - once with the singer in the frame and once without. Before the shot we marked where the lift began on the ground so we could move it back to that point for the second shot. The speed of the lift was pretty variable, but we tried our best to track at the same rate.
In post (FCP), I had to do some frame matching because I think the camera got bumped a little bit between shots. So I enlargened the frames a bit so I could move around one shot to match the other. Then after about 100 attempts, a little skill and a little luck, I got the frames to blend perfectly.
Omiemac - as far as step by step instructions for exporting, it really depends on what NLE you are using to edit on. I used Final Cut Pro, and the process went something like this.
1) File --> Export --> Quicktime Conversion
2) Click the Option button next to the Quicktime Format
3) Click Settings and use the H.264 codec (the HD codec for quicktime)
4) Click Size to resize your image (remember to keep the same proportions)
**For my video I resized it to about 33%, which was 426 width x 240 height.
(The width is actually 426.66, but when I rounded up it added a blank green line on the frame, so you don't want that!)
5) Make sure the box is checked for Internet Streaming if you plan on making it available online.
I think that was about it. The H.264 codec is pretty freakin' sweet when it comes to data compression.
