swiperstopswiping
What are the cons of using a magnet on the viewfinder in order to flip display correctly while using a M2 35mm for example??
cheezweezl said:isn't there already a magnet in the dvx that flips the lcd when you flip it? isn't that why the magnet trick works? seems logical and if so obviously a magnet will not hurt it. i use the magnet trick and no problems...
cheezweezl said:try fliping the magnet over or rotating it. the polarity must be correct.
twocik23 said:The magnet trick only works for the older dvx cameras.
This being said magnets still are a bad thing around tapes in general not to mention fragile minidv's. I am in the same boat trying to save on an external however there are many pros to an external monitor over lcd to add to pile of "why not to put a magnet there".wmiller@csulb.edu said:I use the magnet trick and it works just fine. The magnet is very very weak. It works perfectly and it saved me from buying an external monitor. It does nothing to actually mess with the LCD screen itself, it triggers the sensor that flips the LCD when you go into selfshoot mode.
