It should be superior with the HVX if only because 720p DVCProHD has a horizontal luminance resolution of 960, and the 960 pixel shifted chips of the HVX should be capable of delivering more than that.booth said:1080 IS superior, not by a massive amount, but if I had to shoot something for cinema theatres I'd go with 1080p .........
But I have to say that absolute ....resolution....is ...not....everything. If I had to pick one killer advantage of the HVX over the HD100 it would probably be that the latter only does 25p in High Definition mode, not 50p. If I had to pick one killer advantage of the HD100 over the HVX it would be handheld ergonomics. (And I've not heard a single voice dispute that, so far.) But if you actually wanted the 24/25fps look (as most on this board seem to), and did 95%+ of your work on the tripod, then neither of these would seem anything like killer advantages to you. Similar arguments apply to P2 being a curse or a blessing.
The trouble with doing any article such as is being discussed here is that it is impossible to cover every eventuality, every comparison, and resolution really is only one aspect of a very complicated equation. The highest resolving camera may not necessarily look the best. And how do you equate a camera which maintains 100% MTF right up to x with another whose absolute resolution exceeds x, but whose MTF starts to tail off way before that of the first camera? Which do you think will look the best?
1080p/25 and the HVX (is it not 1080psf/25?) may well give a resolution advantage over 720p/50, but to me the resolution gain is not worth the drop from 50fps to 25fps - a REAL advantage the HVX has over the HD100. To others the gain may be. But things are often far more complicated and interleaved than they first seem.
