yes John play nice. remember we arn't supposed to insult eachother.
kwoff said:David--I really don't think you have anything to apologize for. I also found John Hudson's post tactless and needlessly combative.
David S. said:Sorry John . . . I'm just a little frustrated.
I be happy to send a CD to anyone who wants to host it.
150 megabytes.
It's not like I'm going shoot a bunch of pine trees.
thefilmaddict said:I'm not sure if I shared this with you guys before (I think that I have), but here are some stills that show the noise issue that I sometimes run into.
http://www.morrisbrothersfilms.net
Is this what you guys are talking about or is this unique to my camera?
John_Hudson said:Thanks for thew stills filmaddict but what am I looking at ? I don't see the noise.
It must be a monitor issue ? What do you view your work on that enables you to see noise ?
PappasArts said:thefilmaddict is it noise or artifacts. See I have seen the HVX live component out to monitors. Noise is in the same ball bark of all the other HD cameras. However, is this something beyond that point?
Take that same shot you did, look at it live on the monitor, then playback from P2 that same position and see if it comes after the encoding process to DVCproHD vs the live signal. The Live signal should look just like the P2 playback if all is working right...
In my book noise is from the ccd's, artifacts are from the codecs. Which is it, or maybe a combo your seeing?
Pappas
When I get the HVX for testing, the monitors that are going to be used are the Sony BVM-D24E1WU 24" HD monitors. Best that it gets in HD monitors!
Kaku told me that he had cleaner results going to his Kona card via HVX component card to DVCproHD vs his P2 card versions of the same shot same codec. Now this is what Kaku told me, I would like to see samples though for proof!
I wish we could put this noise/artifacts issue or no issue to permanent rest. I have not read walters article fully, however I didn't notice him having issues with major noise on either the HD100 or HVX. Like I said I haven't read it in full though.
Also 1080P from the HVX CC's better with nearly no blockies vs 720P when pushing the image. That's why I am surprised that 1080P is not ever pushed here as the only option for the best image possible. Maybe it's the fixation on ( which is 99% useless to me ) variable frame rates on the HVX that keeps people at 720P. Bigger frame is always better! Shoot 1080P on the HVX....
Pappas
