Buffalo Link Player -- For your HVX HD footage!!!!
Kholi
Section Moderator
For everyone asking for a solution to playback your Hi-Def content, whether at home or on someone elses HD-TV:
Added: Toshiba and HD-DVD to Standard DVD-R:
http://reviews.cnet.com/Toshiba_HD_A1/4505-6463_7-31736203.html
-- AVS forum post on how to get the HD content to work on the Toshiba -- http://www.avsforum.com/avs-vb/showthread.php?t=667462&highlight=h+264
UPDATE!!! : The process for creating an HD-DVD with a standard DVD!!! NOTE: You CAN fit an entire movie on one Disc, you simply have to know how to do it. For the method listed below, you can fit 40minutes of footage onto an HD-DVD. That means ONE SHORT MOVIE!!!! !HURRRAAAAHHH!!! You MUST CONVERT YOUR HD FOOTAGE TO HDV/MPEG2 before doing this!
k, here is a detailed step-by-step:
STEP 1-
You need a HD Video (1080i and 720p both worked for me)
STEP 2-
Open Ulead DVD MovieFactory 5
STEP 3-
Select "NEW" project.
STEP 4-
Select "HD DVD"
STEP 5-
Select "Add Media" and find the HD Video from step 1
STEP 6-
Select "NEXT" and set-up your menu if desired
STEP 7-
Select "NEXT" then select "Create HD DVD Folders" check box. Make sure you know where the folder will be saved. When this is completed go to step 8
STEP 8-
Open up Nero 6.6 and select Nero Burning Rom. Select DVD-Video from left menu.
Next, click the "NEW" box.
STEP 9-
The left half of the next screen is your new DVD, the right half is you files. Find the HDDVD_TS folder you created in step 7 from the right side and drag it over to the left (Your new HD DVD). Notice that the option to burn the DVD is ghosted, preventing you from creating the new HD DVD...no problem, lets go to step 10.
STEP 10-
Go to your desktop and create a new text file. To do this right click on the desktop and select NEW. Then select TEXT DOCUMENT. Now right click this file and select "rename". Rename the file "VIDEO_TS.VOB" and drag it into to Nero screen. You need to drop it into the folder "VIDEO_TS" (it has the red folder icon).
Now notice what just happened....the "BURN THE CURRENT COMPILATION" icon has become un-ghosted. MIRACLE! WOW!
STEP 11-
Burn the damn DVD
STEP 12-
Put the DVD in the Toshiba HDA1 HD-DVD Player
STEP 13-
WOW...it works!
: I will go into more detail on how to create a DVD with a full length movie in a bit. :
Buffalo Link Player -- http://www.buffalotech.com/products/product-detail.php?productid=96
Added: Another player with HDMI out capabilities, not yet available in the US -- http://www.z500series.com/
While not new, it seems that not a lot of people know that it exists. This is a practical solution for those whom want to port something lightweight to a friends house for viewing.
Price: I've seen 250.00 already and I barely looked. You can probably fine one cheaper.
The concept: Burn a DVD-R with WMV-HD (or Divx-HD) on it, and play it back as you would a regular DVD. The only difference is, you get Hi-Def clarity!!! You can also stream the hi-def video, because this peripheral is wireless. Networking capabilities are always awesome when you have a HTPC (home theatre PC) setup going already.
The Advantage: Lightweight, portable possibilities, and best of all: Encode your already awesome HVX footage to WMV-HD and show some friends at their own home!!
Disadvantage: Only Component out. That means no DVI out or HDMI out... I like my DVI signal. But component is more universal between HD- Televisions anyway... so it's not really a disadvantage at all.
Cords/Cables: Invest in some hi-quality Component cables. S-video and Composite (red,yellow,white) are NOT hi-def signals. Though HVXguy says his S-video signal still looked yummy to his tummy. (That's not a quote, by the way.)
Why not wait for/buy a HD-DVD Player?: Because, you need an HD-DVD burner to get the HD content onto a blank HD-DVD disc. Want to know how much they're going to cost? =)
So, this is what I see as a NOW solution for those wanting to show HD content to people who don't have HTPC's or any other way to view it. You can use your camera, I'd suppose... but I think this might be a tad bit easier. That's me thinking, of course.
Keep in mind... you might want to actually display the content on a HD or HD-ready television... or it's quite pointless.
Thanks to HVXguy, he's the one I found this through.
Kholi said:
Cords/Cables: Invest in some hi-quality Composite cables. S-video and Component (red,yellow,white) are NOT hi-def signals. Though HVXguy says his S-video signal still looked yummy to his tummy.
You've got it backwards. The composite connection uses a yellow colored connector, and separate red and white connectors for audio. Component uses three different connections just for video, and does carry a high-def signal (composite does NOT)
thefilmaddict said:
Do any of you guys own this? Do you like it?
Yes, it OK for what it does. I use it to check our stock footage out.
You can stream lower bitrate material from a computer through the link player. But playing WMV burned on a DVD-R plays smoothly. I now have the component cables and it does look much cleaner.
It glitches here and there with audio, I have not had that much time to sit-down and relax to play movies!!!
Mike Schrengohst
www.MotionZoneHD.com
I ALWAYS get that backwards. LOL. Everytime I say "component", someone says no.."composite", then it's the other way around.
I hate that.
Thanks, Cam-Ra.
Mike Schrengohst
You should do a real test, HVXguy, and give us a hands-on review. I'm actually thinking about purchasing one, now.
I have one and have been playing with it for 2 weeks.
Only drawback I have seen is that wmv content that I have created using Edius has audio sync problems. The audio is literally 1-2 seconds behind video. I called Buffalo tech support and they have had reports of this problem and do not have a fix yet. However some wmv files that I have downloaded don't have this problem. So there may be a workaround. I am tryin several options now.
However mpg HD at 18300kbps 1280x720 24p looks real good and has no audio problems. I am pleased just to be able to watch the footage at all for now.
Keep in mind that it plays actual mpgs and wmv files right off the root of a dvd. There is no menu or demuxing or anything. You just pick the file and select it and it plays. However there are no chapter capabilities in mpg or wmv that is can see. So if you have a 1 hour piece you will have to fast forward through all of it. And honestly.....it is kinda sluggish.
One last cool thing is that if you install the Link Server software on your PC you can share all your itunes and music files across the wireless/wired network. This works great.
Video does not stream reliably for me but I don;t really care.
It also supports a USB hard drive so I am about to test putting my wmv and mpg2 HD files on that instead and not even have to burn!
Peace!
Peace!
Great input. Good to know for anyone considering. Other than having a mini-shuttle HTPC, I really can't see another way to get HD content to a friends or clients regular HD tv if they don't already have the capability of playing them.
Check out this player as well:
HDMI out is the ticket. Unfortunately it's not available in the US yet. I've been keeping an eye on it ans it should be soon. It's gotten a lot of good user feedback on the forums.
One thing to keep in mind...these first generation networked players aren't using the chipset to deal with H264. The new generation chip will.
Sweeet. Now that's what I want. HDMI to DVI. I'm sold. =P
WMV-HD is actually, in my opinion, just as good as H.264. H.264 is just a bit more widepread/well-known.
Added that link to the first post so that it's there as well.
True. DIVX HD is probably better or as good as either one. It's just my opinion that H264 will be the be-all-end-all-iPod of the HD codecs. But then Bill Gates is trying hard to make sure that doesnb't happen.
WMV-HD and DIVX-HD will give you plenty to mess around with. It would just be nice to have H264 included to make it a 'complete' player.
BTW - you CAN order the Zensonic from down under. Just don't know about the warranty hassle.
How much?? I want it. I have a Toshiba DVD SD player with HDMI out, very nice. This player could easily take it's place!
Mike Schrengohst
Mike Schrengohst
Yeah seriously. I think I want this like NOW. LOL
Even though I have a HTPC, after researching a bit more, I would really like to have a back-up plan for screening my stuff on other people's televisions.
I know a lot of people who have televisions with Component inputs already, even a letterboxed presentation of Hi-Def content on those televisions would still kick ass.
Adding a HDMI output and the ability to play H264 would make it a perfect portable player. Any idea when the US will get players like that?
Keep an eye on their forums and site for availability here. Like I said, you CAN order it from Australia. If you do, make sure the distributor gives you the hack for the DVD region codes. You can also find the hack yourself to make it region free.
The price is somewhere in the $300 range. Can't remember exactly. Seriously, read through their forum. They release firmware upgrades quite often so the OS is pretty bug free. Plus they implement new features with the updates. They've been through the hiccups of new product release, bug fixes, etc.
I'm just waiting on the release here cause I'm a bit sketchy on the whole warantee aspect.
Look out for an announcement from Jaykers VERY soon on a U.S release.
Quoted from the Zensonic forum. It was posted April 19.
Sounds like this forum a couple months ago when nobody could get their hands on an HVX!
