DavidBeier
I've heard it mentioned a lot but what exactly is the process (as non technical as possible) and what are the drawbacks?
Barry_Green said:There is no documentation on the process, Canon refuses to divulge their technique.
Graeme Nattress has said he believes it's a realtime de-interlace, where there's one valid field and one interpolated field. Adam Wilt has said that the results look consistent with a simple one-field system (field duplication). I think it's probably some variation on Frame Mode.
The drawbacks are:
1) it's not as high-resolution as the 60i mode. 60i looks like it delivers upwards of 750 lines, 24F delivers around 550-600.
2) 24F mode is incompatible with any other equipment, it can only be played back on a Canon XLH1.
The benefits are that it appears to deliver a temporal signature equivalent to 24p.
David Jimerson said:You would think to quell speculation, Canon would release its specs.
David Jimerson said:Elton, I'm pretty sure you misread me a while back. I said that 24F motion should be identical to 24p and that there should be no motion artifacts.
The HVX and HD100 are about the same, the XLH1 is about 15% more or so.How do the horizontal rez's compare in 24f to the HVX and HD100?
DavidBeier said:I remember reading that the HVX200 had roughly 540 lines and the pansonic about 650. If this is the case, why does the Canon footage still look sharper?
