marlenedegrood
Flicks By Chics
PaPa said:JEEEEZ! the +7 CO changes the picture 1000% How much does that +7 CO cost? And how does it effect the distance between the dvx and the GG compared to the +10 asian that alot of people are using?
actually i got more than that..
Marlene, would the + 4 asian shorten the distance between the dvx and the GG as well as give more distortion around the edges than a +10 asian?
The higher the + value of the macro, the shorter or longer the distance becomes between the dvx and the GG ? So which one would give the least distortion around the edges?
The 58mm +7 CO at B&H Photo is $209
I'm not sure what you mean by "shorten the distance". Are you talking about physical distance or focus distance?
I'm going to be experimenting with my adapter design this weekend to see if I can rid myself of using the +4 with the +7 CO. But if I can't then that's ok since it's the +10 Asian Macro that causes the most aberation and distortion.
I'm very happy with the results of using the +7 CO and it's well worth the money, especially since the adapter just isn't worth using if you're going to use the +10 Asian macro.
On the plus side the +10 Asian macro makes a great desktop paper weight and doubles as a magnifier for pulling splinters out of your hand. So it's not a complete waste of money
