First preliminary res test of HVX-200e
Im anxious to see some noise comparisons with the PAL HVX. Push it to its limits and record it, i want to see!!!
Hi Anders, thanks for the effort but you cannot test the ccd camera from a displayed chart on an lcd with a similar res! To take any usefull conclusions the resolution difference should be 10 times higher!
But there IS one way that you could use your monitor:
You can crop a part of the chart, enlarge it on photoshop (bicubic) e.g 5 times to reach the resolution of your monitor and then display it fullscreen.
Then, take the camera back 5 times further (or zoom out) so that the cropped part will be 1/5 of your horizontal or vertical frame dimension. You can frame it at the center of your lens or at the edges to see the differences.
Yes I know. This was actually to test the color sampling compared to the white chart.
Well, don't want to cause any fuss, so I took it down for now :-)
We know a lot about ntsc version, so if somebody somewhere could bring both ntsc and pal version to the same temporal and spatial testing space, that would be very helpful...
