Guide To Cleaning The DVX100(a) Recording Heads
Barry,
I have cleaned tape paths and head assemblies for years and just wanted to add one little tid bit to your very informative article.
I would suggest to all who attempt this proceedure to be, as Barry indiciates, very careful. NEVER NEVER NEVER WIPE THE CHAMOS VERTICALLY ALONG THE HEAD DRUM. If you contact a head in one of the veritcal strokes, the chances are pretty good that you will break a head. NEVER NEVER EVEN THINK OF USING COTTON SWABS EVER. THE COTTON FIBERS WILL DISLODGE AND CLOG THE HEADS.
Secondly, I have used a cleaner for years that works wonderfully on the tape path including all guides and tape lifters and it leaves absolutely no residue. It can be purchased in just about any headware store. It is de-natured alcohol. AS BARRY STATES, NEVER USED ISOPROL OR RUBBING ALCOHOL FROM THE DRUG STORE.
De-natured alcohol is the primary ingrediant in professional head cleaning from years back when Ampex make the VTR tape decks for the broadcast industiry. Ampex head cleaner was the choice for studio professionals hands down. Never use this on the rubber pinch roller!!!
As to a good rubber cleaner and conditioner, conditioning the rubber is as important as cleaning it. It is easy to clean the deposits from the rubber (with much patience) but doing this without drying out the rubber is KEY. If the rubber becomes dry from cleaning, without a conditioner, it gets heard and will eventually crack but when it becomes hard is when you will encounter problems. I have found several rubber conditioners that are pretty good but given the extreemly tight confines of the area in which you have to work, it may be best to leave this alone since leaving behind some residue can be more of a problem than the good you are tying to accomplish. Hope all finds this helpful.
Great illustrations Barry!!
Hi Barry S,
I've been following this thread about cleaning the DVX recording head. My DVX gave me a warning light telling me that my recording head is dirty & I've read from this thread that it is not advisible to use the cleaning tape as it is abrasive for the record head. I'm left with two options then :
1) To take it to the Panasonic service center for them to clean the head for me.
2) To follow your instruction very carefully & clean the head myself.
I understand that option 2 is very risky as being my first time, I'll have to get it right the first time, else I might damage some components. But I also would not like to depend too much on Panny to do the cleaning for me as they would charge a service fee for it & the service center is quite far from where I live. Btw, my DVX is still new & still covered under warranty should anything happen to it.
Barry, since my DVX is under warranty, what would be your advice on cleaning the head? Do it myself, or take it to Panny for them to clean? I'm on a tight schedule as this Saturday, I've got a shoot.
If I were to follow your instructions very carefully, are there any other precauations I should take careful note off that you did not cover in your original explanation? Em.....jkb242, since you have considerable amount of experience cleaning tape heads, what would be your advice for me?
Eventually, my goal would be to master the skill of cleaning my own recording head so that I would have learnt a valuable skill & not have to depend on Panny. Thanks very much in advance for your helpful advice.
Andrew
I purchased a bottle of Radio Shack Tape Head Cleaner and it lists the contents as; "Isopropanol (67-63-0), Ethanol (64-17-5), and Methanol (2.8%) (67-56-1)" will this do the job, engineers?
Can I use video 90 for cleaning the head? It's a pray.
My DVX-100AE gives me distorted image, black horizontal bars etc. And if I keep playing the tape, I get an error: unplayable tape (other format)
since this thread is a bit old...many of the links to the supplies are dead
does anyone have any current links to supplies needed?
reuse swabs
reuse swabs
I read over the entire thread a few times over the last month or two and don't recall seeing whether or not it was ok to reuse chamois swabs. If I consistently used one for isopropyl, and one for the rubber cleaner, could I use them for multiple cleaning jobs?
picture links
picture links
Interesting comment about old links. I am going to clean up my directories. I posted some illustrations. Are they of any value? If they are, great. I'll leave them. If there is no value, I would like to clean them up too.
Chris
I'm right there with you on that. My dvx still only has about 4hrs on it but i've been capturing off my old gs12 and the heads are beyond dirty on it, it won't even play a tape now. I went to 3 radio shacks in an attempt to find the cleaning ingredients with no luck, can anyone recommend a common chain store that might have them? Office depot? walmart? walgreens?
How to open drive door to clean heads
Hi Barry,
....just one quick question. The heads are way down at the bottom of the tape carriage once it retracts. Do you actually have to REMOVE the door and or/tape carriage to get to the heads? or do I just have to use an extra long stick with the cleaner at the end? Many thanks.
I have run into the Red 'x' problem with my DVX100A. At first I ran the head cleaner and that did not resolve the problem, so I took it to a panasonic facility and had the heads cleaned. The error still persists? Any suggestions?
Also, all of the footage shot while the red 'x' was blinking plays back perfectly. Does a red 'x' ever come on when there is not an issue? Yet, there is obviously an issue if the error is present.
Ok, just catching up here.
--Don't reuse the chamois swabs! They're dirty.
--The important part is the isopropyl alcohol and the synthetic chamois swabs. Both are easy to find by googling them. The rubber conditioner is much less imporatant, so I wouldn't sweat it if you can't get it easily.
--Nothing has to be disassembled to clean the heads and most of the tape path, but some people find it easier to remove the door. The chamois sticks with the angled heads work pretty well.
--If the red X persists, you need to get your camera in for service.
intermittent shooting
On my DVX 100 there was an option for intermitten shooting. I can't find this on the 100B:(
Barry,
Does the self cleaning on the 100b work well enough to keep the manual cleaning at longer intervals?
Ken
I live in Norway and the price of a clean is quite a bit more than a beer up here!!!Rude!
I saved a small fortune and had a lot fun but used about 2 hours from start to finish oh and a lot of blu-tack to help get the screws back in the door.
Cheers
which one of these is better/advisable to use :
AF ISOCLENE ISOPROPANOL CLEANING SPRAY
or
Isopropyl Alcohol (Propan-2-ol, IPA) -(liquid bottle)
or is it just splitting hairs and either will do?
Can't recomend the Panasonic dry lube tapes
I'm sorry folks but I found the problem.
I've ran about 8 Pany tapes through my DVX and got the red X.
Bummer to get head clogs so quickly. I took off the door and cleaned the heads and transport mechanism. Low and behold the swab touching the tottom of the compartment came up filthy. I mean practically black. I found the problem of DVX frequent head clogs. It's the dry lube tapes. The dry lube must be this powder all over inside and I mean all over. Everywhere I run the swab it comes up gunk. I'm doing a total clean inside as much of the area as I can get to then switching back to the sony wet lube tapes. Sorry Pany but my only conclusion to all this black stuff inside a camera with less than 10 hrs. on it can only be the tape. My backup to this theory is all the folks here at DVXuser who see this red X.
I have some sort of spec on the inside of the stock lens, which can be seen as an out of focus spec on my footage. I also have put 170 hours on my dvxa. If I sent it to an authorized dealer, do you think they'd get rid of the spec and clean the heads for a flat fee of $100? Or would it cost more?
Thanks,
Mike
My local Radioshack and Best Buy don't have any of the materials for this! A lot of the links mentioned earlier are outdated as well. Where can I find this stuff?
