As stated somewhere, Adobe's new Premiere Pro 2 doesn't support Panasonic's P2 and MXF, so people who are used to PPro seem to be out of luck.
As an avid Avid user, I decided to have a look at the new PPro2, as I might want to use it for going uncompressed out on a DecklinkHD.
And it's true: premiere doesn't like MXF, and refuses to look at it. But then I started poking around a bit, and lo and behold, after 5 minutes I was editing P2 files in Premiere nativly!
The trick seems to be the way FCP uses P2, namely, a quicktime wrapper. In Avid, I select all my P2 clips at once and export them as a quicktime reference file. This process takes only 1 second. A Qt ref-file is only about 8kb.
Then over to Premiere, simply import those quicktime reference files( also a 1 second job), and your up and running.
I admit, not a very elegant solution( you have to have both Avid and PPro2), but it works quite well( minimal manual work), and moreover, it opens perspectives for a better workaround for those wanting to cut on PPro: it must be quite simple to write a small app that creates a QT-ref file for the MXF's you throw at it.
It does not mean however, that I'm gonna start cutting on Premiere, I way prefer my Avid. Long ago I started on Premiere( 4.2 I believe) as a hobby, now I'm editing on Avid professionaly, and haven't looked back since. But still, it's nice to have options.
