You simply go to the "motion" fane on your player screen and set the tracking so that it increases during the shot. Thsi can be done by setting some dots in the beginning of the shot ten increacving travking during the shot up until the end. Try it and youll learn...........Like I did.
Yea you need to select a starting point and then set a keyframe then you may need to adjust the scale slider to zoom in a little and set another key frame and then adjust the scale again and set another keyframe. You have to keep doing this process until you want the zooming to stop and you should have what you wanted in the end.
