Good Morning,
I am currently running a Zoom H5 on top of my Sony A7RII. The Zoom is attached via a Sescom 3.5 mm Line to Mic -25 dB Audio Cable for Zoom H6 (9"). Line-Level of cable is plugged into Zoom and other into camera mic.
Line out on Zoom is currently not set to adjust any audio levels and in camera settings are Audio Rec Level 1, Audio out timing - Live, Wind Noise - off, Audio Record - On
The problem is, I feel i'm not getting the best audio on playback in my video files. Even when I record bird sounds or surrounding noise it comes out very low and soft even on the Zoom its self. The only sounds that are great would be sharper louder noise that are very close by. When I am recording into Zoom, I monitor audio with head phones and distant sounds are perfect in headphones but not so much on playback. I have my pre amps set to almost 9 on the shotgun mic.
In editing, I have to boost the audio DB for SFX and then you get that stereo noise which makes it unusable because it sounds bad.
The reason for the zoom, is I also run a wireless mic via XLR in the back from time to time.
Do I have the wrong cable into camera or is the zoom not set up correctly?
Thank you for the help
