I have only had the H4n for a couple of months, i'm not expert on it but usually use it on films with the two xlr inputs and set the mics and do my main job of DP and working the camera. Lately i have been doing a lot of filming casually and simply using the on board mics on the H4n and mounting it on my GH2.
I seem to be having an issue with my H4n, I am in stereo mode using the on board mics. I push record and that starts the preview levels. The left mic level is very low almost not even there while the right channel is in the middle area and active. This has been happening all week. Is it possible to set the on board mic levels separately? For example like you would usually set the rec levels by simply pressing the rec level on the side, that seems to effect both at once never independently set each. or do you think i have a busted left mic =(.
I would really appreciate any help in fixing the matter, especially if i don't have to send it on the warranty if its not a matter of damaged goods.
