So I conducted some tests
and found that there is a bleed from the two channels on the zoom h4n...at least for me.
wondering if anyone else has experienced this?
I basically took 2 lavs and put them in two separate rooms. I put the zoom in stereo recording mode on the two lavs (also did it in 4 channel with the same results on the two input channels)
I recorded and turned the tv on in both rooms and then turned one off in one room then turned it back on and went to the other room and did the same thing.
brought the audio into final cut pro and listened to both tracks. when the tv was off in one room it was still hearing the audio from the other room and vice versa. I contacted the people at zoom about this and they haven't gotten back to me
to make sure there wasn't something strange going on I did the exact same test on my hvx 200 plugged into the 2 channels on the camera and there was no bleed happening. I feel strongly that it is the zoom h4n 2 input channels.
...it seems to me that the two audio input tracks on the zoom h4n are not properly shielded and it is causing the slight bleed. I just found this to be an issue....wondering if I did something wrong and if anyone else has experienced this?
let me know
Ronster
let me know
Ronster
