Zoom control?
getken
I've looked through all the settings in the menus and through the instruction manual that comes with the HVX. Is there any way to control the zoom speed? Can it go any faster? When using an external zoom controller is there more leeway? TIA
THere are three zoom speeds (low, middle, high). The main zoom rocker on the body of the camera is variable-speed, the further you press it the faster it goes.
The small zoom rocker on the top of the handle is single-speed. Set the 1/2/3 switch on the side of the handle to "3" and the top rocker will run at the top speed.
If you want really fast zooms, set the SERVO/MANU switch on the bottom front of the camera to MANU, and then you'll have complete manual control and you can do super-fast snap zooms, far faster than any competing servo-driven camera can do.
