I've been on the lookout for a headlamp that I could use for cycling, canoeing and bushwalking. For cycling it has to have a long throw, for canoeing it has to be waterproof, for bushwalking it has to be light and compact. In addition, I would like it to be well-engineered, aesthetic, and efficient.
I had my doubts I would ever see such a device, until I saw the Zebralight H51. And then I thought: Maybe it could even be used for video lighting. It is optimized to run off 1 AA Eneloop, has several brightness settings, and weighs less than 100 gms. At maximum setting it draws about 2 Amps from the battery (~2.5 Watts) and runs for about an hour.
I don't own a video camera yet. When I do, it will be the GH2. Until then I'm researching in detail all aspects of the equipment I'll need. To help me decide, I'd like some comment on the suitability of the H51 for video lighting.
I imagine I may want to use it to light up people in a dim forest, or around a campfire, or under a bridge at night. Not to try and turn night into day, but just to throw enough light on a subject so that what might have been an unusable situation, turns into an acceptable situation. My partner and I would have a light each, so two would be available. But it gets complicated because there are four options in the H51 range (http://www.zebralight.com/Headlamp_c_7.html), all using the Cree XP-G (http://www.cree.com/products/pdf/XLampXP-G.pdf)
I do not have any experience with video lighting, so I'm wondering which would be the best bet.
Q1: Is an 11º spot a good idea, or would the flood version (more even lighting, though less bright) be better?
Q2. Which colour temperature (cool or neutral) would give the most natural results? This would depend, of course, on how well the GH2 can compensate for different colour temperatures.
To help answer these questions, I have located two videos. The first (http://www.youtube.com/watch?v=I8gV7-A4EB8) shows the difference between the cool white and the neutral. The second (http://www.youtube.com/watch?v=u8IbX0tvQLg&feature=related) is a more detailed comparison between the flood version ("F") and the hot spot version. Note that this video is actually of the SC51 and SC51F, which are optically identical to the H51 and H51F, but are normal torches, not head torches.
In the second video, the most interesting bits as far as I am concerned are:
2.30: Comparison of colour temperature (51/51W)
3.05: Inside comparison of flood vs spot (51/51F)
5.35: Outside comparison of flood vs spot (51/51F)
Given that I will be buying two of these torches, which two should I buy that would be most useful for video lighting? Two of the same; two different?
H51
The base unit. 200 lumens max, cool white (6100K-6500K), 80° beam spread, 11° (3.8 feet at 20 feet) hot spot.
H51F
Flood version. 190 lumens max, cool white, 90° beam spread, no hot spot.
H51W
Neutral version. 172 lumens max, neutral (4200K), 80° beam spread, 11° (3.8 feet at 20 feet) hot spot.
H51FW
Flood neutral version. 164 lumens max, neutral (4200K), 80° beam spread, no hot spot.
H51F
H51W
H51FW
