zacuto viewfinder accessories with it
deleuze3
Hi, the zacuto v pro, if you have a gorilla plate, you can use an adhesive.
If you have the gorilla plate as I did, u can use a z finder frame (tall frame 3'', battery grip frame 3'', small frame 3'')
I have a gorilla plate with my canon60d. Which z finder frame of 3'' I need?
Thanks in advance
Not sure what to make of your post ?
But let's assume you meant that you have a Zacuto Z-finder pro ?
And you wonder which frame you should use if you want to connect it to the gorillaplate and not the adhesive frame ?
The small frame unless you use a battery grip of course.
You do realize you could have gotten the answer to this question (assuming this was the question) by just going onto the Zacuto website ?
